メインコンテンツにスキップ
Samsung Galaxy Note II Midframe Replacement
必要な工具と部品
  1. Samsung Galaxy Note II Midframe Replacement, Stylus: 手順 1、 2の画像 1 Samsung Galaxy Note II Midframe Replacement, Stylus: 手順 1、 2の画像 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Midframe Replacement, Rear Case: 手順 2、 2の画像 1 Samsung Galaxy Note II Midframe Replacement, Rear Case: 手順 2、 2の画像 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Midframe Replacement: 手順 3、 3の画像 1 Samsung Galaxy Note II Midframe Replacement: 手順 3、 3の画像 2 Samsung Galaxy Note II Midframe Replacement: 手順 3、 3の画像 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Midframe Replacement, MicroSD Card: 手順 4、 3の画像 1 Samsung Galaxy Note II Midframe Replacement, MicroSD Card: 手順 4、 3の画像 2 Samsung Galaxy Note II Midframe Replacement, MicroSD Card: 手順 4、 3の画像 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Midframe Replacement, Battery: 手順 5、 2の画像 1 Samsung Galaxy Note II Midframe Replacement, Battery: 手順 5、 2の画像 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Midframe Replacement: 手順 6、 1の画像 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Midframe Replacement, Midframe: 手順 7、 1の画像 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Midframe Replacement: 手順 8、 3の画像 1 Samsung Galaxy Note II Midframe Replacement: 手順 8、 3の画像 2 Samsung Galaxy Note II Midframe Replacement: 手順 8、 3の画像 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Midframe Replacement: 手順 9、 3の画像 1 Samsung Galaxy Note II Midframe Replacement: 手順 9、 3の画像 2 Samsung Galaxy Note II Midframe Replacement: 手順 9、 3の画像 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Midframe Replacement: 手順 10、 2の画像 1 Samsung Galaxy Note II Midframe Replacement: 手順 10、 2の画像 2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Midframe Replacement: 手順 11、 2の画像 1 Samsung Galaxy Note II Midframe Replacement: 手順 11、 2の画像 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Midframe Replacement: 手順 12、 2の画像 1 Samsung Galaxy Note II Midframe Replacement: 手順 12、 2の画像 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Midframe Replacement: 手順 13、 2の画像 1 Samsung Galaxy Note II Midframe Replacement: 手順 13、 2の画像 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Midframe Replacement: 手順 14、 2の画像 1 Samsung Galaxy Note II Midframe Replacement: 手順 14、 2の画像 2
    • Lift the display assembly out of the midframe.
終わりに
52 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
471,489 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,418のガイドは作成済み
5 件のコメント
There are two hidden clips near battery housing. One inside in upper part of battery housing and the second below battery near antenna.
milankerslager - 返信
How do I fix the glass
Nena Summer Perez - 返信
Very good job you are doing. It is very helpful to us. Thanks for sharing your knowledge to the people my wishes are with you god bless you.
HARDIK PANCHOLI - 返信
very very very useful brother
Arunkrishna T H - 返信
Brilliant Thanks.
michaeleggar6 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 30,454
