メインコンテンツにスキップ
Samsung Galaxy Note Edge Vibrator Replacement
必要な工具と部品
  1. Samsung Galaxy Note Edge Vibrator Replacement, Battery: 手順 1、 1の画像 1
    • Power down your device and make sure that it is turned off.
    • Place the phone with the screen facing down on a clean flat surface.
  2. Samsung Galaxy Note Edge Vibrator Replacement: 手順 2、 3の画像 1 Samsung Galaxy Note Edge Vibrator Replacement: 手順 2、 3の画像 2 Samsung Galaxy Note Edge Vibrator Replacement: 手順 2、 3の画像 3
    • Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
    • Remove battery by using your Supdger on the notch located directly underneath battery location.
    • During the creation of this guide, we did not have access to a battery in our device.
  3. Samsung Galaxy Note Edge Vibrator Replacement, Motherboard: 手順 3、 1の画像 1
    • Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
    • Remove the stylus from the stylus holder.
  4. Samsung Galaxy Note Edge Vibrator Replacement: 手順 4、 3の画像 1 Samsung Galaxy Note Edge Vibrator Replacement: 手順 4、 3の画像 2 Samsung Galaxy Note Edge Vibrator Replacement: 手順 4、 3の画像 3
    • Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
    • Insert your spudger into the stylus socket and pry the midframe from the phone.
    • Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
  5. Samsung Galaxy Note Edge Vibrator Replacement: 手順 5、 2の画像 1 Samsung Galaxy Note Edge Vibrator Replacement: 手順 5、 2の画像 2
    • With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone.
    • Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
  6. Samsung Galaxy Note Edge Vibrator Replacement: 手順 6、 3の画像 1 Samsung Galaxy Note Edge Vibrator Replacement: 手順 6、 3の画像 2 Samsung Galaxy Note Edge Vibrator Replacement: 手順 6、 3の画像 3
    • Using your Spudger's pointed end, pry off the following leads that connect these parts to the logic board in the top left hand corner:
    • Front Facing Camera
    • AMOLED Display Screen
    • AMOLED Capacitive Screen
  7. Samsung Galaxy Note Edge Vibrator Replacement: 手順 7、 3の画像 1 Samsung Galaxy Note Edge Vibrator Replacement: 手順 7、 3の画像 2 Samsung Galaxy Note Edge Vibrator Replacement: 手順 7、 3の画像 3
    • At the top end, gently insert pointed end of spudger underneath the motherboard.
    • Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard.
    • Remove the motherboard from the device.
  8. Samsung Galaxy Note Edge Vibrator Replacement, Vibrator: 手順 8、 1の画像 1
    • Insert the sharp end of the spudger underneath the golden cables connecting the vibration motor. Gently pry upwards to disconnect them.
  9. Samsung Galaxy Note Edge Vibrator Replacement: 手順 9、 3の画像 1 Samsung Galaxy Note Edge Vibrator Replacement: 手順 9、 3の画像 2 Samsung Galaxy Note Edge Vibrator Replacement: 手順 9、 3の画像 3
    • Insert one end of the Tweezers into said notch. Pry upwards and grab the round piece to remove the vibration motor.
    • Adhesive holds the motor in place, so force is required to break this bond.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Duc Huynh
メンバー登録日: 04/19/18
253 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S22-G6, Maness Spring 2018 Cal Poly, Team S22-G6, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S22G6
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 330
