はじめに
The headphone jack is the port you connect your headphone to in order to receive the sound from the tablet through headphones. Over time, the headphone jack or the terminal connections can become worn out or damaged, which may result in headphones not receiving sound properly. In this case, the headphone jack has to be replaced and this guide will show you how.
必要な工具と部品
Remove the two 4.5-mm black phillips head screws using a #00Phillips screwdriver.
6 の人々がこのガイドを完成させました。
3 件のコメント
this did not help getting the broken headphone jack out of my Samsung note 8
