メインコンテンツにスキップ
Samsung Galaxy Note 8.0 Back Cover Replacement
必要な工具と部品
  1. Samsung Galaxy Note 8.0 Back Cover Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Samsung Galaxy Note 8.0 Back Cover Replacement: 手順 2、 1の画像 1
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Samsung Galaxy Note 8.0 Back Cover Replacement: 手順 3、 1の画像 1
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
終わりに
16 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Joel
メンバー登録日: 09/23/14
1,862 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 12-2, Blackwell Fall 2014 USF Tampa, Team 12-2, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S12G2
4 メンバー
16のガイドは作成済み
5 件のコメント
news flash that phone in the picture is NOT a note 8
Nic Wilson - 返信
As stated in the title, this is regarding Galaxy Note 8.0 ( 2013 ), not for Note 8 Phone.
deadyoda -
Thanks for the guide, helped me to add a QI module into my Galaxy Note 8.0
deadyoda -
Thanks for sharing this useful guide! Also, if issue is related with software, we can use unbrick guide to get it repair.
Cheers!
Deepak Gupta - 返信
Thanks for sharing this info for the basic understanding. I always wanted to do this but afraid of the consequences.
Even I sell mobile covers in my shop from Mobile Back Covers.
Really helpful for me to explain my customers.
Invite Celebrate - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 34,035
