メインコンテンツにスキップ
Samsung Galaxy Note 5 Back Cover Replacement
必要な工具と部品
ビデオの概要
  1. Samsung Galaxy Note 5 Back Cover Replacement, Samsung Galaxy Note 5 Back Cover Replacement: 手順 1、 1の画像 1
    • Heat the back cover to melt the strong adhesive sticker underneath.
  2. Samsung Galaxy Note 5 Back Cover Replacement: 手順 2、 1の画像 1
    • Try to pull and open a gap between back cover and frame after heat. Insert into a guitar pick to cut the sticker.
    Is it possible to pull it without breaking it?? :/
    Mohammad - 返信
  3. Samsung Galaxy Note 5 Back Cover Replacement: 手順 3、 1の画像 1
    • If you do it hardly, you need much more heat especially the edged side.
    • Slipping a playing card through the gap is a good way to loosen up the adhesive.
  4. Samsung Galaxy Note 5 Back Cover Replacement: 手順 4、 1の画像 1
    • Remove the back cover. The white stripe is the sticker.
終わりに
45 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Sophia
メンバー登録日: 03/25/14
43,810 ポイント
62のガイドは作成済み
9 件のコメント
What about putting the one back on?
rcf917 - 返信
will it go back on and stay on without new adhesive?
dfasdfjiun - 返信
I suggest that you take new adhesive, old adhesive is not strong enough to hold back cover.
Witrigs -
You can check this video of put it back battery cover : https://www.youtube.com/watch?v=3HrmeVGY...
Witrigs - 返信
How do I remove the sticky part
Marcelino Lopez - 返信
How to put the cover back will there be a sticker in battery cover. And from where I will get to buy that
BIJLI R - 返信
Where do you find the replacement back for sale? I looked on the Samsung site, and no luck.
Marty Meyer - 返信
Hey I know its old but amazon has some back covers
Francisco Vazquez -
Anyone have a problem with one that is bricked won't charge and won't turn on but yet a wireless charger appear to be giving it a charge as light goes solid on charger when it is in contact what should I do this phone looks in great shape almost new condition
Johnathon Patterson - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 35
今までの合計 108,772
