はじめに
Use this guide to replace the front-facing camera on your Samsung Galaxy Note 4.
必要な工具と部品
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery.
Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Grasp the cap of the S Pen and remove it from its slot in the midframe.
Turn the motherboard over.
Lift the metal tab up with the tweezers.
Turn the motherboard back over.
Unclip the two plastic clips that connect the rear camera to the motherboard with your fingers.
14 の人々がこのガイドを完成させました。
3 件のコメント
I change my LCD screen and camera stopped working. I bought new one and still no result. Please help !
stopped front camera
