メインコンテンツにスキップ
Samsung Galaxy Note 4 Antenna Replacement
必要な工具と部品
  1. Samsung Galaxy Note 4 Antenna Replacement, Midframe: 手順 1、 1の画像 1
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  2. Samsung Galaxy Note 4 Antenna Replacement: 手順 2、 3の画像 1 Samsung Galaxy Note 4 Antenna Replacement: 手順 2、 3の画像 2 Samsung Galaxy Note 4 Antenna Replacement: 手順 2、 3の画像 3
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  3. Samsung Galaxy Note 4 Antenna Replacement: 手順 3、 1の画像 1
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  4. Samsung Galaxy Note 4 Antenna Replacement: 手順 4、 3の画像 1 Samsung Galaxy Note 4 Antenna Replacement: 手順 4、 3の画像 2 Samsung Galaxy Note 4 Antenna Replacement: 手順 4、 3の画像 3
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  5. Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: 手順 5、 2の画像 1 Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: 手順 5、 2の画像 2
    • Pull up on the connectors with tweezers to detach them from the phone.
    • The blue dot on the shorter connector belongs nearest the bottom of the phone.
終わりに
19 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Derek Nola
メンバー登録日: 01/06/15
2,244 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 70-6, Forte Winter 2015 Cal Poly, Team 70-6, Forte Winter 2015人のメンバー
CPSU-FORTE-W15S70G6
4 メンバー
16のガイドは作成済み
6 件のコメント
hi where can i buy an antenna connector ?
i live in india.
ramumohan007 - 返信
Google kar le
ravi raj -
I broke the actual ports that the antenna cables connect to on the mother board. Is thereally away to fix them or do I have to replace the whole logic/motherboard? I would like to keep my logic/motherboard because I don't want to lose all my text messages. What should I do?
shanonsmitt16 - 返信
I also broke the connector component on the motherboard. It remains attached to the blue cable. Could this be re-soldered?
Leanahtan Eiddiwnid - 返信
Is there a make shift way to put a extra antenna using one the two antenna ports above and to the left of the standard antenna cable. Without make any holes on the housing its self
Pedro A Sosa - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 18
今までの合計 23,297
