メインコンテンツにスキップ
Samsung Galaxy Note 4 Headphone Jack Replacement
必要な工具と部品
  1. Samsung Galaxy Note 4 Headphone Jack Replacement, Rear Case: 手順 1、 2の画像 1 Samsung Galaxy Note 4 Headphone Jack Replacement, Rear Case: 手順 1、 2の画像 2
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy Note 4 Headphone Jack Replacement, Battery: 手順 2、 1の画像 1
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
  3. Samsung Galaxy Note 4 Headphone Jack Replacement, SIM Card: 手順 3、 2の画像 1 Samsung Galaxy Note 4 Headphone Jack Replacement, SIM Card: 手順 3、 2の画像 2
    • Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
  4. Samsung Galaxy Note 4 Headphone Jack Replacement, Midframe: 手順 4、 1の画像 1
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  5. Samsung Galaxy Note 4 Headphone Jack Replacement: 手順 5、 3の画像 1 Samsung Galaxy Note 4 Headphone Jack Replacement: 手順 5、 3の画像 2 Samsung Galaxy Note 4 Headphone Jack Replacement: 手順 5、 3の画像 3
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  6. Samsung Galaxy Note 4 Headphone Jack Replacement: 手順 6、 1の画像 1
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  7. Samsung Galaxy Note 4 Headphone Jack Replacement: 手順 7、 3の画像 1 Samsung Galaxy Note 4 Headphone Jack Replacement: 手順 7、 3の画像 2 Samsung Galaxy Note 4 Headphone Jack Replacement: 手順 7、 3の画像 3
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  8. Samsung Galaxy Note 4 Headphone Jack Replacement, Headphone Jack: 手順 8、 3の画像 1 Samsung Galaxy Note 4 Headphone Jack Replacement, Headphone Jack: 手順 8、 3の画像 2 Samsung Galaxy Note 4 Headphone Jack Replacement, Headphone Jack: 手順 8、 3の画像 3
    • Use the plastic spudger and tweezers to remove the headphone jack from the middle housing.
  9. Samsung Galaxy Note 4 Headphone Jack Replacement: 手順 9、 2の画像 1 Samsung Galaxy Note 4 Headphone Jack Replacement: 手順 9、 2の画像 2
    • Pry the headphone jack up from the midframe.
終わりに
21 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Derek Nola
メンバー登録日: 01/06/15
2,244 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 70-6, Forte Winter 2015 Cal Poly, Team 70-6, Forte Winter 2015人のメンバー
CPSU-FORTE-W15S70G6
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 20,043
