この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide shows how to replace the camera.
必要な工具と部品
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Slide your fingernail or plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
Lift the battery out of its recess.
Insert the plastic opening tool into the Stylus Pen placement holder.
Lift the plastic opening tool so that the midframe separates from the base.
Unclip the camera connecting cable using the plastic opening tool from the motherboard
Remove loose camera from base
37 の人々がこのガイドを完成させました。
3 件のコメント
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
I shall be very thankfull for this act of kindness
