メインコンテンツにスキップ
Samsung Galaxy Note 3 Rear Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove the rear case: 手順 1、 1の画像 1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: 手順 2、 2の画像 1 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: 手順 2、 2の画像 2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Why... is it not simple enough already lol
    Adam Ahmed - 返信
  3. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: 手順 3、 2の画像 1 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: 手順 3、 2の画像 2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Rear Facing Camera Replacement, S Pen: 手順 4、 1の画像 1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unscrew Back Chassis: 手順 5、 1の画像 1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Back Chassis: 手順 6、 1の画像 1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: 手順 7、 2の画像 1 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: 手順 7、 2の画像 2
    • Remove the single screw beside headphone jack.
    You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
    Oriol Felisart - 返信
  8. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: 手順 8、 2の画像 1 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: 手順 8、 2の画像 2
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Motherboard Removal: 手順 9、 1の画像 1
    • Pull up on the motherboard with tweezers.
    Can i change at&t board to 9002 or 9005??,
    Ayyaz - 返信
    My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
    soha Javed - 返信
    My wifi hotspot is not working
    Kiran Thopate - 返信
  10. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unclipping the Camera: 手順 10、 1の画像 1
    • Unclip the camera connecting cable using the plastic opening tool from the motherboard
    • Remove loose camera from base
終わりに
37 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Brittany Gail
メンバー登録日: 09/23/14
8,504 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 2-2, Blackwell Fall 2014 USF Tampa, Team 2-2, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S2G2
4 メンバー
25のガイドは作成済み
3 件のコメント
Awesome, phone disassembly and fingernail painting at same time :) Thanks for your time to post this!
Chris G - 返信
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
hameidfehri - 返信
I shall be very thankfull for this act of kindness
Malik wajdan ali - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 13,428
