はじめに
This explains how to gain access to components behind the motherboard.
必要なもの
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Slide your fingernail or plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
Lift the battery out of its recess.
Insert the plastic opening tool into the Stylus Pen placement holder.
Lift the plastic opening tool so that the midframe separates from the base.
Use tweezers to remove both antenna clips.
Use a spudger to disconnect six cable connectors.
74 の人々がこのガイドを完成させました。
4 件のコメント
I'm looking for the screws for this phone, but all the search hits I've come across are for the screwdriver. Any leads on where I can find the screws?
Jared Lunt - 返信
I want to replace motherboard of galaxy note 3 SM-N900 with SM-N9005. Is it possible and can it convert 3g to 4G. Because my phone doesn't support 4G .it is 3g and I want to make it 4G .what should I do help me
I am also looking for the same question
