はじめに
This guide explains the way to replacing the headphone jack.
必要な工具と部品
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Slide your fingernail or plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
Lift the battery out of its recess.
Insert the plastic opening tool into the Stylus Pen placement holder.
Lift the plastic opening tool so that the midframe separates from the base.
Lift the spudger to separate the jack assembly from the motherboard.
Pull to remove.
23 の人々がこのガイドを完成させました。
