メインコンテンツにスキップ
Samsung Galaxy Note 10.1 Battery Replacement
必要な工具と部品
  1. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: 手順 1、 3の画像 1 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: 手順 1、 3の画像 2 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: 手順 1、 3の画像 3
    • This is the back of the device and where you will begin to take it apart
    • It is neccesary to remove this piece first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: 手順 2、 3の画像 1 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: 手順 2、 3の画像 2 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: 手順 2、 3の画像 3
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: 手順 3、 3の画像 1 Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: 手順 3、 3の画像 2 Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: 手順 3、 3の画像 3
    • Carefully remove all of the ribbons that connect over the battery.
  4. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: 手順 4、 3の画像 1 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: 手順 4、 3の画像 2 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: 手順 4、 3の画像 3
    • Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
    Thanks for Tutorial, Note 10.1 works. :-)
    What can I do with the old battery?
    Peter Hesse - 返信
終わりに
49 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Tyler Salomone
メンバー登録日: 09/22/14
1,020 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 3-7, Brown Fall 2014 USF Tampa, Team 3-7, Brown Fall 2014人のメンバー
USFT-BROWN-F14S3G7
3 メンバー
9のガイドは作成済み
13 件のコメント
In Step 3, mention that you need to lift up on the black locks to take out the ribbons.
John Peterson - 返信
Actually, on my device one lock was colored faun (beige). Lift them seen from the edge of the Note, not on the cable side.
dada64 -
Also, mention that you can disconnect the battery from the device by gently pulling out the battery and gently lifting up the wires.
John Peterson - 返信
This is not a plug to be pulled in the direction of the cables but vertically off the board. Putting it back in you simply plug the contacts down first, then the cable side of the plug.
dada64 -
When replacing the back cover, hook the bottom edge into the frame along the edge before trying to snap the rest in place along the sides.
charliesmallman55 - 返信
I have just replaced a battery on my Galaxy Note 10.1. Today, after charging the battery to abt 65 % I attempted to restart the unit but it failed.
I have a figure code to open the programs but it would not accept my "drawing". I also note that the calendar on the front is january 1st (no Year) The clock is also incorrect. The unit automatically connect to my broadband router. What on earth can be wrong or have I done wrong?
Best regards
John Hegg
John A Hegg - 返信
I've replaced my battery and now my sd card is not recognized.
carolinared - 返信
The rear of my Galaxy Note doesn't have the ridge under the camera to ease the back off like your Pic 1.
Any clues as to how to remove the back cover please which appears to be all in one piece with no edges to use my plastic lever ?
Thanks Chris
Chris Hockey - 返信
I broke one ribbon lock (in my device it is black). How can i replace it?
camiloapt87 - 返信
Re step 3: after pulling tape off, look for micro latches on 3 of the ribbons...they lift up...making it easier to remove and then reset afterwards.
S Frank - 返信
Does one really need to buy a rear panel? It is the battery that is going to be replaced right?
Kerry - 返信
thanks sir
I want ask you , this battery not found at my country and I couldn’t import it from outside
someone told me that there is possibility to connect 2 batteries for another 2 mobiles different from this tablet
provided that they are same volts same as tablet battery
Is that possible sir ?
asrd rami - 返信
I replaced the battery in my N8013 and now colour is all green. It was OK before. LCD cable lines up correctly. Any ideas ?
Robert Stables - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 34
過去 30 日: 118
今までの合計 88,534
