メインコンテンツにスキップ
はじめに
If your headphones don't seem to be working properly when you plug them into your Samsung Galaxy Note 10, this guide should help you solve this issue. Before starting this guide, look into purchasing a tool set from iFixit's website, that is where you will find the tools referenced in this guide. As with any electronic device, be sure to wear anti-static gloves while performing repairs on the device.
  1. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: 手順 1、 3の画像 1 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: 手順 1、 3の画像 2 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: 手順 1、 3の画像 3
    • This is the back of the device and where you will begin to take it apart.
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use a metal spudger to pop up the corner of the silver piece.
    • Use the plastic opening tools to pry along the edges of the silver piece.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 手順 2、 3の画像 1 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 手順 2、 3の画像 2 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 手順 2、 3の画像 3
    • Remove the three 5mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 手順 3、 3の画像 1 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 手順 3、 3の画像 2 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 手順 3、 3の画像 3
    • Remove the three 2 mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Starting with the black motherboard connector, remove the module indicated by the orange box in the second picture.
    • Replace the 3.5 mm auxiliary port with a similar model.
終わりに
Gavin Tipker
メンバー登録日: 2018年11月01日
193 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S3-G1, Harley Fall 2018 IUPUI, Team S3-G1, Harley Fall 2018人のメンバー
IUPUI-HARLEY-F18S3G1
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 9
今までの合計 834
