メインコンテンツにスキップ
Samsung Galaxy Nexus Main Display Glass Replacement
必要な工具と部品
  1. Samsung Galaxy Nexus Main Display Glass Replacement, Removing Back Cover: 手順 1、 1の画像 1
    • Open the back cover of the phone with your fingers or use the plastic opening tools to pry the back cover off of the phone.
    • Remove the battery by prying it free from the divot at the bottom.
    • Store the back cover and the battery in a safe place, such as a bowl, until you are ready to re-install them.
  2. Samsung Galaxy Nexus Main Display Glass Replacement: 手順 2、 1の画像 1
    • Remove the four 4.5 mm Phillips screws from the rear of the phone.
  3. Samsung Galaxy Nexus Main Display Glass Replacement: 手順 3、 2の画像 1 Samsung Galaxy Nexus Main Display Glass Replacement: 手順 3、 2の画像 2
    • Flip the phone over so that the screen faces upward.
    • Insert a plastic opening tool into the seam between the screen and the outer case. Work the plastic opening tool around the phone without removing it from the seam.
    • Slowly pry the outer case from the screen.
    • Work carefully. Excessive force can easily damage the case.
  4. Samsung Galaxy Nexus Main Display Glass Replacement: 手順 4、 3の画像 1 Samsung Galaxy Nexus Main Display Glass Replacement: 手順 4、 3の画像 2 Samsung Galaxy Nexus Main Display Glass Replacement: 手順 4、 3の画像 3
    • Remove a single 4 mm Phillips #00 screw from the bottom of the phone.
    • Lift up the flat connector from its socket on the motherboard.
    • Lift the entire headphone jack assembly from the phone.
  5. Samsung Galaxy Nexus Main Display Glass Replacement: 手順 5、 2の画像 1 Samsung Galaxy Nexus Main Display Glass Replacement: 手順 5、 2の画像 2
    • Disconnect the two ribbon cables from the motherboard.
  6. Samsung Galaxy Nexus Main Display Glass Replacement: 手順 6、 1の画像 1
    • Using tweezers or a spudger, lift the vibrator motor from its recess in the midframe.
  7. Samsung Galaxy Nexus Main Display Glass Replacement: 手順 7、 2の画像 1 Samsung Galaxy Nexus Main Display Glass Replacement: 手順 7、 2の画像 2
    • Using tweezers, gently disconnect the antenna cable from its socket on the motherboard.
  8. Samsung Galaxy Nexus Main Display Glass Replacement: 手順 8、 2の画像 1 Samsung Galaxy Nexus Main Display Glass Replacement: 手順 8、 2の画像 2
    • Use tweezers to pull the motherboard out of the phone.
    • Work carefully. Depending on the model, the underside of the motherboard may still have ribbon cables connecting it to the display assembly.
  9. Samsung Galaxy Nexus Main Display Glass Replacement: 手順 9、 3の画像 1 Samsung Galaxy Nexus Main Display Glass Replacement: 手順 9、 3の画像 2 Samsung Galaxy Nexus Main Display Glass Replacement: 手順 9、 3の画像 3
    • Starting near the USB port, use your tweezers to pull the small daughterboard from the phone.
終わりに
13 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Carmine Tenaglia
メンバー登録日: 09/15/13
320 ポイント
1ガイドが承認済み
チーム
Oakland University, Team 1-17, Ruszkiewicz Fall 2013 Oakland University, Team 1-17, Ruszkiewicz Fall 2013人のメンバー
OAK-RUSZKIEWICZ-F13S1G17
1 メンバー
1のガイドは作成済み
2 件のコメント
with this guide , I found this repair easy to do. Thank you Tom G.
Thomas Giles - 返信
Deberían d3 poner los diagramas eléctricos para reparar gracias
manchadoshow - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 20,671
