はじめに
When you plug in your headphones into the headphone jack, do you not hear anything?
This guide will help you solve that problem!
Follow step 1 through 8, then skip to step 13.
必要な工具と部品
You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
This is when a new battery will be inserted.
2 の人々がこのガイドを完成させました。
