メインコンテンツにスキップ
はじめに
This guide instructs on how to replace the motherboard.
パーツ
パーツは指定されていません。
  1. Samsung Galaxy Mega Motherboard Replacement, Battery: 手順 1、 3の画像 1 Samsung Galaxy Mega Motherboard Replacement, Battery: 手順 1、 3の画像 2 Samsung Galaxy Mega Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
    Bonjur vule vondre de telefon samsung galaxy mega ecron
    bucuresteanugigel - 返信
    samsung galaxi mega
    0751571718 samsung galaxi mega
  2. Samsung Galaxy Mega Motherboard Replacement: 手順 2、 3の画像 1 Samsung Galaxy Mega Motherboard Replacement: 手順 2、 3の画像 2 Samsung Galaxy Mega Motherboard Replacement: 手順 2、 3の画像 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Motherboard Replacement, Midframe: 手順 3、 3の画像 1 Samsung Galaxy Mega Motherboard Replacement, Midframe: 手順 3、 3の画像 2 Samsung Galaxy Mega Motherboard Replacement, Midframe: 手順 3、 3の画像 3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
    If you insert a spudger from the battery compartment seam, you can start the opening without damage to the outside.
    Ted - 返信
  4. Samsung Galaxy Mega Motherboard Replacement: 手順 4、 2の画像 1 Samsung Galaxy Mega Motherboard Replacement: 手順 4、 2の画像 2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Remove the 2.55 mm Phillips #000 screw from the motherboard panel.
  6. Samsung Galaxy Mega Motherboard Replacement: 手順 6、 3の画像 1 Samsung Galaxy Mega Motherboard Replacement: 手順 6、 3の画像 2 Samsung Galaxy Mega Motherboard Replacement: 手順 6、 3の画像 3
    • Remove the connector clips on motherboard.
  7. Samsung Galaxy Mega Motherboard Replacement: 手順 7、 2の画像 1 Samsung Galaxy Mega Motherboard Replacement: 手順 7、 2の画像 2
    • Remove the final motherboard connectors.
  8. Samsung Galaxy Mega Motherboard Replacement: 手順 8、 3の画像 1 Samsung Galaxy Mega Motherboard Replacement: 手順 8、 3の画像 2 Samsung Galaxy Mega Motherboard Replacement: 手順 8、 3の画像 3
    • Lift motherboard gently with finger.
    • There is a total of six connectors on the motherboard that need to be removed. All of them are shown in the pictures in this guide, make sure all of them are disconnected before removing.
終わりに
8 の人々がこのガイドを完成させました。
Max Rathman
メンバー登録日: 2016年02月04日
861 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S17G2
4 メンバー
8のガイドは作成済み
5 件のコメント
Where can I buy a motherboard replacement for Mega 6.3 GT-I9205/I527?
valuesphilippines - 返信
Is there an international market to buy mobile phone hardware? I can not find motherboard for this phone in my country (online).
lukhman - 返信
Where can I buy the motherboard replacement for G. Mega 6.3 19200
Thats dae - 返信
i cant turn on my galay mega 6.3 afrer update phone is like DEAD!!!  please help me…..for Samsung mega gt-i9205
mirza baig - 返信
This app is the best
Mazen Noufal - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 5,237
