メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Mega Front Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Mega Front Facing Camera Replacement, Battery: 手順 1、 3の画像 1 Samsung Galaxy Mega Front Facing Camera Replacement, Battery: 手順 1、 3の画像 2 Samsung Galaxy Mega Front Facing Camera Replacement, Battery: 手順 1、 3の画像 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Galaxy Mega Front Facing Camera Replacement: 手順 2、 3の画像 1 Samsung Galaxy Mega Front Facing Camera Replacement: 手順 2、 3の画像 2 Samsung Galaxy Mega Front Facing Camera Replacement: 手順 2、 3の画像 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: 手順 3、 3の画像 1 Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: 手順 3、 3の画像 2 Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: 手順 3、 3の画像 3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Galaxy Mega Front Facing Camera Replacement: 手順 4、 2の画像 1 Samsung Galaxy Mega Front Facing Camera Replacement: 手順 4、 2の画像 2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Galaxy Mega Front Facing Camera Replacement, Front Facing Camera: 手順 5、 1の画像 1
    • Remove the one 2.55 mm Phillips #000 screw from top left of motherboard assembly.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Galaxy Mega Front Facing Camera Replacement: 手順 6、 1の画像 1
    • Remove metal cover with plastic opening tool.
    FixBotに聞いてみる
    コメントを追加
  7. Samsung Galaxy Mega Front Facing Camera Replacement: 手順 7、 2の画像 1 Samsung Galaxy Mega Front Facing Camera Replacement: 手順 7、 2の画像 2
    • Lift the motherboard connector and remove the camera assembly from phone.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Max Rathman
メンバー登録日: 02/04/16
915 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S17G2
4 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 37
今までの合計 1,158
