メインコンテンツにスキップ
はじめに
This guide instructs on how to replace the front facing speaker and LED blinker.
パーツ
パーツは指定されていません。
  1. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: 手順 1、 3の画像 1 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: 手順 1、 3の画像 2 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: 手順 1、 3の画像 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 手順 2、 3の画像 1 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 手順 2、 3の画像 2 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 手順 2、 3の画像 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: 手順 3、 3の画像 1 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: 手順 3、 3の画像 2 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: 手順 3、 3の画像 3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 手順 4、 2の画像 1 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 手順 4、 2の画像 2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Earpiece Speaker/LED Indicator: 手順 5、 1の画像 1
    • Remove the black 2.55 mm Phillips #000 screw.
  6. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 手順 6、 1の画像 1
    • Remove the metal cover with the plastic opening tool.
  7. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 手順 7、 2の画像 1 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 手順 7、 2の画像 2
    • Remove the motherboard clip from speaker assembly to the motherboard.
    • Gently lift the speaker and LED assembly out of the device.
    • Speaker assembly may be glued to the device, gently pry until it releases.
終わりに
3 の人々がこのガイドを完成させました。
Max Rathman
メンバー登録日: 2016年02月04日
861 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S17G2
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 861
