メインコンテンツにスキップ
Samsung Galaxy Mega 2 LCD/Digitizer Replacement
必要な工具と部品
  1. Samsung Galaxy Mega 2 LCD/Digitizer Replacement, LCD/Digitizer: 手順 1、 1の画像 1
    • Before beginning, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: 手順 2、 2の画像 1 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: 手順 2、 2の画像 2
    • Locate the battery
    • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
    • Remove the battery
  3. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: 手順 3、 3の画像 1 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: 手順 3、 3の画像 2 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: 手順 3、 3の画像 3
    • Use phillips head PH000 and remove all 13, 1.4 mm visible screws.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use the pry tool to disconnect the digitizer
  4. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: 手順 4、 3の画像 1 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: 手順 4、 3の画像 2 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: 手順 4、 3の画像 3
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembly frame.
    • Be careful and do not lift the screen completely off yet, leave the screen at an angle.
    • Use the heat gun to heat up the bottom to loosen the adhesive from the menu and back buttons.
    • Once heated, gently pull the screen upward.
    • Make sure that the buttons are separating from the adhesive.
  5. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: 手順 5、 3の画像 1 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: 手順 5、 3の画像 2 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    購入する
    • Flip the screen over.
    • Locate the LCD/Digitizer.
    • Then disconnect the LCD/Digitizer using tweezers.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Taylor Powell
メンバー登録日: 09/08/17
780 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team S1-G6, Virtue Fall 2017 Western Carolina University, Team S1-G6, Virtue Fall 2017人のメンバー
WCU-VIRTUE-F17S1G6
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 19
今までの合計 1,820
