メインコンテンツにスキップ
Samsung Galaxy Mega 2 Front Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Mega 2 Front Facing Camera Replacement, Front Facing Camera: 手順 1、 1の画像 1
    • Before beginning, make sure phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Front Facing Camera Replacement: 手順 2、 2の画像 1 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 手順 2、 2の画像 2
    • Locate the battery.
    • Use pry tool or fingernail to lift up on the battery.
    • Remove the battery.
  3. Samsung Galaxy Mega 2 Front Facing Camera Replacement: 手順 3、 3の画像 1 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 手順 3、 3の画像 2 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 手順 3、 3の画像 3
    • Use phillips head PH000 and remove all 13, 1.4 mm screws as shown.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use tweezers to disconnect the digitizer.
  4. Samsung Galaxy Mega 2 Front Facing Camera Replacement: 手順 4、 3の画像 1 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 手順 4、 3の画像 2 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 手順 4、 3の画像 3
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembling frame.
    • Remember once the screen is off, completely remove it from the mid-frame.
    • To remove the mid-frame from the motherboard, press down on the top right corner of the frame and the mid-frame should release from the motherboard.
    • When it releases use tweezers to pick up on the mid-frame to completely separate it from the motherboard.
  5. Samsung Galaxy Mega 2 Front Facing Camera Replacement: 手順 5、 3の画像 1 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 手順 5、 3の画像 2 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 手順 5、 3の画像 3
    • Locate the camera in the top left corner.
    • Lift the motherboard connector and remove the camera assembly from phone.
終わりに
作成者
5人の作成者と共同で作成されました。
Taylor Powell
メンバー登録日: 09/08/17
753 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team S1-G6, Virtue Fall 2017 Western Carolina University, Team S1-G6, Virtue Fall 2017人のメンバー
WCU-VIRTUE-F17S1G6
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 708
