メインコンテンツにスキップ
Samsung Galaxy Mega (SGH-M819N) Front Display Assembly Replacement
必要な工具と部品
ビデオの概要
  1. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove battery and rear door.: 手順 1、 2の画像 1 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove battery and rear door.: 手順 1、 2の画像 2
    • bold textWith a heavily shattered screen lay some tape over it to protect yourself and to keep it all in one place.
    • Flip the phone over to remove the batter door and battery.
  2. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove Phillips Screws and Speaker componant.: 手順 2、 2の画像 1 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove Phillips Screws and Speaker componant.: 手順 2、 2の画像 2
    • With a phillips remove all 14 visibile screws.
    • Using your pry tool slowly pop the speaker companant off.being careful not to damage it
  3. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove rear assembly frame: 手順 3、 3の画像 1 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove rear assembly frame: 手順 3、 3の画像 2 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove rear assembly frame: 手順 3、 3の画像 3
    • Using the pry tool work your way arounf the phone, separating the rear assembly frame from the device.
    • the frame can be deceiving and seem as if it attached closer to the top but in the picture you will see down to the middle is where you should look to separate.
    • Fully remove the rear assembly frame from the main device.
  4. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove the LCD Cable and the Front Camera: 手順 4、 3の画像 1 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove the LCD Cable and the Front Camera: 手順 4、 3の画像 2 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove the LCD Cable and the Front Camera: 手順 4、 3の画像 3
    • Using a spudger or pry tool lift remove the LCD flex cable from the logic board.
    • Next with a phillips screwdriver remove the one screw holding the protection plate over the cameras,
    • Proceed to remove the front camera
  5. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Using heat to soften the adhesive: 手順 5、 3の画像 1 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Using heat to soften the adhesive: 手順 5、 3の画像 2 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Using heat to soften the adhesive: 手順 5、 3の画像 3
    • With your heat hun slowly heat the screen while using pry tool to work your wau around the device.
    • With atleast 3 guitar pick keeping separation as you progress the screen should slowly start lifting off.
    • leave the bottom area for last and be careful with your tools to not damage the back cable.
  6. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove bad LCD: 手順 6、 1の画像 1
    • Clean device then follow the steps in reverse.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Austin Pollard
メンバー登録日: 02/05/17
1,474 ポイント
3のガイドは作成済み
チーム
Reno Phone Repair Reno Phone Repair人のメンバー
Business
1 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 13
今までの合計 1,713
