はじめに
Use this guide to replace a cracked or broken screen on your Samsung Galaxy M51.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device.
必要な工具と部品
Insert a SIM eject tool into the small hole on the SIM card tray on the left edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Apply a suction handle to the back cover, as close to the USB-C port as possible.
Lift the back cover's bottom edge with your suction handle, opening a slight gap between the back cover and the frame.
Insert the tip of an opening pick in the gap you created.
Slide the opening pick to the bottom left corner and leave it there.
Insert a second opening pick and slide it from the bottom left corner to the bottom right corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Use the pointy end of a spudger to disconnect the fingerprint sensor from the motherboard.
Insert an opening pick between midframe and display near the usb-c port.
Slide the opening pick to bottom right corner to release the plastic clips.
Use the flat end of a spudger to disconnect the display cable from the daughterboard.
Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
Apply a suction handle near the bottom edge.
Pull up on the suction up with strong, steady force to create a gap.
Insert an opening pick into the gap between display and the frame.
Insert a second opening pick and slide it to the bottom right corner to cut the adhesive.
Leave the opening pick in its place to prevent the adhesive from resealing.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
8 の人々がこのガイドを完成させました。
9 件のコメント
Vielen Dank, für diese Anleitung! Ich würde auch gerne diese Anleitung nutzen, um mein kaputtes Display selbst zu tauschen, jedoch finde ich in den Weiten des Internets kein Ersatzglas für das M51. Kann mir jemand einen passenden link nennen? Da ich nichts passendes gefunden habe, wäre meine nächste Frage, ob das Display vom S20 Plus kompatibel wäre, da es die gleichen Maße misst..?Vielen Dank im voraus!
Vg
Marv
Marv Zockt - 返信
Hi,
such mal nach einem M515 Display-Glas. Das ist kompatibel.
Mfg
Merci beaucoup !
Grâce à vous j’ai pu changer moi même l’écran de la collègue amie de ma mère et elle va être très heureuse !
Vous apportez de la joie, et vos tutos sont vraiment de qualité bravo !
Antoine
Is a71 screen compatible with m51?
Humko abhi sikna hai
Good explaining amazing with images I understood very clearly
Very good explaining with images I learnt how to replace display of samsung
Hi, thank you!
Hi, thank you for the guide. However there is one thing I am not sure about: is there any recommendation about what kind of adhesive to use? Unfortunately ifixit don't seem to have an adhesive kit for this phone.
Is something like Zhanlida T-8000 or B-7000 glue something that would work fine?
Thanks
