メインコンテンツにスキップ
Samsung Galaxy Luna LCD display Replacement
必要な工具と部品
  1. Samsung Galaxy Luna LCD display Replacement, LCD display: 手順 1、 1の画像 1
    • Attach a small suction cup to the lower half of the glass screen.
  2. Samsung Galaxy Luna LCD display Replacement: 手順 2、 1の画像 1
    • Apply pressure to the middle section of the screen while pulling up the lower edge by pivoting your wrist.
  3. Samsung Galaxy Luna LCD display Replacement: 手順 3、 1の画像 1
    • Once you've opened a large enough gap, insert a Spudger tool between the glass and the motherboard.
    • Slide the Spudger tool around the gap until the screen is completely separated from the motherboard.
    • The LCD is very fragile,be careful when sliding the spudger around the gap.
  4. Samsung Galaxy Luna LCD display Replacement: 手順 4、 2の画像 1 Samsung Galaxy Luna LCD display Replacement: 手順 4、 2の画像 2
    • Pull the rear panel up and away to completely separate it.
    • make sure the panel is completely detached from the phone frame before separating it.
  5. Samsung Galaxy Luna LCD display Replacement: 手順 5、 3の画像 1 Samsung Galaxy Luna LCD display Replacement: 手順 5、 3の画像 2 Samsung Galaxy Luna LCD display Replacement: 手順 5、 3の画像 3
    • Place the spudger tool between the LCD and the glass screen.
    • Slide the spudger tool in between the screen and the display until both are completely separated from each other.
    • The LCD is very fragile, do not apply excessive force when prying the glass panel
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
xingyu chen
メンバー登録日: 02/14/18
266 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S6-G1, Eyestone Spring 2018 USF Tampa, Team S6-G1, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S6G1
4 メンバー
5のガイドは作成済み
2 件のコメント
Hola, cual es el numero de parte de la pantalla a reemplazar?
Luis A. Andueza - 返信
It appears that OEM screens are no longer available for this phone. I was able to find this third party display assembly that looks like it would work, but I can’t attest to its functionality, so there would be a bit of risk involved for you. Hope that helps!
Austin Blakely -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 1,043
