メインコンテンツにスキップ
Samsung Galaxy Light Rear Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Back Cover: 手順 1、 1の画像 1
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Battery: 手順 2、 1の画像 1
    • Remove the battery from the device.
  3. Samsung Galaxy Light Rear Facing Camera Replacement, Unscrew Midframe: 手順 3、 1の画像 1
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Midframe: 手順 4、 1の画像 1
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: 手順 5、 3の画像 1 Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: 手順 5、 3の画像 2 Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: 手順 5、 3の画像 3
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
  6. Samsung Galaxy Light Rear Facing Camera Replacement, Rear Facing Camera: 手順 6、 1の画像 1
    • Use a plastic opening tool to disconnect the rear facing camera from the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
Geoff Wacker
メンバー登録日: 09/30/13
90,313 ポイント
89のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 552
