はじめに
Use this guide to restore your Samsung Galaxy J7 V to working order with a motherboard replacement. This guide covers steps for replacing a motherboard by going through how to get under the screen, removing the front panel, the home button, and the battery of the phone to get to the motherboard itself.
必要な工具と部品
Insert a Jimmy tool under one of the corners of the display and gently raise the display.
Locate the socket of the home button.
Fit the metal spudger in between the socket and the home button.
Use the indent on the right side of the phone to lift up the backing
With the phone faced downwards, remove the backing of the case, lifting up from the right side
Carefully remove the battery by lifting the bottom side, and then fully remove the battery
