はじめに
Use this guide to replace a cracked or dead screen in your Samsung Galaxy J5.
If the frame is warped, it is important to replace it to make sure the new screen fits properly and does not suffer damage from uneven pressure.
Before disassembling your mobile, discharge the battery below 25%. The battery could catch fire and / or explode if accidentally punctured, but the chances are much lower if it is discharged.
Note: This guide tells you how to replace the screen only, leaving the original chassis and motherboard in place. However, some replacement screens come pre-installed in a new chassis, which requires a very different procedure. Make sure you have the correct part before you start following this guide.
You will need replacement adhesive to re-glue the components when reassembling the device.
必要な工具と部品
To reassemble the device, follow these instructions in reverse order.
10 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
2 件のコメント
Certo ma se devi cambiare la batteria? Rompi lo schermo al 99%
