はじめに
This guide will walk you through the process of replacing a not working back camera in a Samsung Galaxy J3V.
必要な工具と部品
Place your thumb on the top left corner and pry the tab open and lift off the back cover.
Remove connector tab with spudger then carefully remove headphone jack with tweezers.
After removing the motherboard, locate and flip tab holding the rear camera's connector.
Carefully use the tweezer to remove the connector and the camera.
ある他の人がこのガイドを完成しました。
