メインコンテンツにスキップ
Samsung Galaxy J3 Prime Battery and SIM Card Replacement
  1. Samsung Galaxy J3 Prime Battery and SIM Card Replacement, Battery and SIM card: 手順 1、 1の画像 1
    • Power off your phone by holding down the power button; located on the top right-hand side of your phone for approximately 5 seconds.
    • Make sure to remove your phone charger if it is plugged in.
  2. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 2、 3の画像 1 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 2、 3の画像 2 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 2、 3の画像 3
    • Turn your phone so the back is facing up.
    • Using your fingers or a spudger, remove the cover by lifting it from the slot located on the top right-hand side underneath the volume buttons.
  3. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 3、 2の画像 1 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 3、 2の画像 2
    • Remove the battery by lifting it up from the slot in the bottom right corner.
  4. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 4、 3の画像 1 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 4、 3の画像 2 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 4、 3の画像 3
    • Slide the SIM card down from the SIM card slot.
    • Make sure to firmly press down on the SIM card when sliding down, for easy removal.
  5. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 5、 2の画像 1 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 5、 2の画像 2
    • Slide the new SIM card into the slot.
    • When you slide the new SIM card in, make sure to place the golden pleated side face down.
    • Now place the new battery into the battery slot by aligning it correctly with the four gold contacts.
  6. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 6、 3の画像 1 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 6、 3の画像 2 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 手順 6、 3の画像 3
    • Put the cover back by sliding it on, and firmly pressing it shut.
    • Power on your phone.
終わりに
作成者
1人の作成者と共同作成されました。
Aisha Bashir
メンバー登録日: 07/01/21
133 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G6, Melo-Thaiss Summer 2021 York University, Team S2-G6, Melo-Thaiss Summer 2021人のメンバー
YORK-MELO-THAISS-SU21S2G6
1 メンバー
1のガイドは作成済み
コメント 1 件
I need to replace the sim card slot on one of these is it individual or does it come out with the whole motherbord and what parts do I need to order?
Mitchell Hedlund - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 760
