メインコンテンツにスキップ
Samsung Galaxy J3 Mission Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy J3 Mission Motherboard Replacement, Back Cover: 手順 1、 1の画像 1
    • Insert your fingernail into the back cover removal slot and gently pull back until the cover pops off.
  2. Samsung Galaxy J3 Mission Motherboard Replacement, Battery: 手順 2、 1の画像 1
    • Make sure that your device is powered off before removing the battery.
    • Insert your fingernail into the battery removal slot and pull back until the battery pops out.
  3. Samsung Galaxy J3 Mission Motherboard Replacement, SD and SIM Cards: 手順 3、 1の画像 1
    • Use your finger to slide the SD and SIM card out of the device.
  4. Samsung Galaxy J3 Mission Motherboard Replacement, Screen: 手順 4、 1の画像 1
    • Use an iFixit opening tool to lift the screen from one of the vertical sides of the phone and continue gently prying until the screen is loose enough to safely remove.
    • The damaged screen is connected under the screen assembly with a small plastic brace; remove this with an iFixit opening tool.
    • Be careful around the home button. It has little tabs to keep it in the frame, but they will break if the adhesive isn’t loosened with age or heat.
  5. Samsung Galaxy J3 Mission Motherboard Replacement, Midframe: 手順 5、 2の画像 1 Samsung Galaxy J3 Mission Motherboard Replacement, Midframe: 手順 5、 2の画像 2
    • Using a Phillips #000 screwdriver, remove all eleven 5mm screws from the metal panel.
  6. Samsung Galaxy J3 Mission Motherboard Replacement: 手順 6、 1の画像 1
    • Turn the device over, and push firmly to separate the metal plate from the back paneling.
  7. Samsung Galaxy J3 Mission Motherboard Replacement, Motherboard: 手順 7、 1の画像 1
    • Carefully lift up the motherboard with your finger starting from the bottom up
    • Motherboard is fragile.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Joseph Toth
メンバー登録日: 09/21/18
686 ポイント
6のガイドは作成済み
チーム
University of North Texas, Team S5-G1, Thompson Fall 2018 University of North Texas, Team S5-G1, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S5G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,027
