メインコンテンツにスキップ
Samsung Galaxy J3 Eclipse Home Button Replacement
必要な工具と部品
  1. Samsung Galaxy J3 Eclipse Home Button Replacement, Display Assembly: 手順 1、 1の画像 1
    • Use a heat gun or hair dryer to heat up the front edges of the phone for about two minutes. Stay approximately six inches away from the screen to prevent phone damage.
    • Do not apply heat to any one edge of the phone for longer than a few seconds. Instead, use a continuous motion around the phone's edges.
  2. Samsung Galaxy J3 Eclipse Home Button Replacement: 手順 2、 2の画像 1 Samsung Galaxy J3 Eclipse Home Button Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • While the screen adhesive is still warm and flexible, insert a pry tool or plastic card between the glass display and the frame of the phone.
    • Slowly slide another pry tool around all the edges of the phone in order to break the adhesive's bond to the display.
    • When using the pry tool, do not use too much force or the phone's internals could be damaged.
    • Do not insert your tool more than 1cm into the top edge of the phone to avoid damaging the fragile cables.
  3. Samsung Galaxy J3 Eclipse Home Button Replacement: 手順 3、 3の画像 1 Samsung Galaxy J3 Eclipse Home Button Replacement: 手順 3、 3の画像 2 Samsung Galaxy J3 Eclipse Home Button Replacement: 手順 3、 3の画像 3
    • Gently lift lower side and loosen all edges to hinge screen up from bottom.
    • Do not try to completely remove the display from the frame yet. Simply try to loosen up all the edges.
  4. Samsung Galaxy J3 Eclipse Home Button Replacement: 手順 4、 3の画像 1 Samsung Galaxy J3 Eclipse Home Button Replacement: 手順 4、 3の画像 2 Samsung Galaxy J3 Eclipse Home Button Replacement: 手順 4、 3の画像 3
    • Use your prying tool to slowly pry up on the bottom right corner of the white cable guard, exposing a thin ribbon cable connector.
  5. Samsung Galaxy J3 Eclipse Home Button Replacement: 手順 5、 3の画像 1 Samsung Galaxy J3 Eclipse Home Button Replacement: 手順 5、 3の画像 2 Samsung Galaxy J3 Eclipse Home Button Replacement: 手順 5、 3の画像 3
    • Pry up the ribbon cable connector revealed from under the cable guard and remove the display from the device.
    • Clean the residue from the phone edges before re-assembling phone with new screen.
終わりに
作成者
5人の作成者と共同で作成されました。
Chandler Casey
メンバー登録日: 09/21/18
792 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team S2-G4, Riccardelli Fall 2018 University of North Texas, Team S2-G4, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S2G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 4
過去 30 日: 6
今までの合計 383
