メインコンテンツにスキップ
Samsung Galaxy J3 Eclipse Display Assembly Replacement
必要な工具と部品
  1. Samsung Galaxy J3 Eclipse Display Assembly Replacement, Display Assembly: 手順 1、 1の画像 1
    • Use a heat gun or hair dryer to heat up the front edges of the phone for about two minutes. Stay approximately six inches away from the screen to prevent phone damage.
    • Do not apply heat to any one edge of the phone for longer than a few seconds. Instead, use a continuous motion around the phone's edges.
  2. Samsung Galaxy J3 Eclipse Display Assembly Replacement: 手順 2、 2の画像 1 Samsung Galaxy J3 Eclipse Display Assembly Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • While the screen adhesive is still warm and flexible, insert a pry tool or plastic card between the glass display and the frame of the phone.
    • Slowly slide another pry tool around all the edges of the phone in order to break the adhesive's bond to the display.
    • When using the pry tool, do not use too much force or the phone's internals could be damaged.
    • Do not insert your tool more than 1cm into the top edge of the phone to avoid damaging the fragile cables.
  3. Samsung Galaxy J3 Eclipse Display Assembly Replacement: 手順 3、 3の画像 1 Samsung Galaxy J3 Eclipse Display Assembly Replacement: 手順 3、 3の画像 2 Samsung Galaxy J3 Eclipse Display Assembly Replacement: 手順 3、 3の画像 3
    • Gently lift lower side and loosen all edges to hinge screen up from bottom.
    • Do not try to completely remove the display from the frame yet. Simply try to loosen up all the edges.
  4. Samsung Galaxy J3 Eclipse Display Assembly Replacement: 手順 4、 3の画像 1 Samsung Galaxy J3 Eclipse Display Assembly Replacement: 手順 4、 3の画像 2 Samsung Galaxy J3 Eclipse Display Assembly Replacement: 手順 4、 3の画像 3
    • Use your prying tool to slowly pry up on the bottom right corner of the white cable guard, exposing a thin ribbon cable connector.
  5. Samsung Galaxy J3 Eclipse Display Assembly Replacement: 手順 5、 3の画像 1 Samsung Galaxy J3 Eclipse Display Assembly Replacement: 手順 5、 3の画像 2 Samsung Galaxy J3 Eclipse Display Assembly Replacement: 手順 5、 3の画像 3
    • Pry up the ribbon cable connector revealed from under the cable guard and remove the display from the device.
    • Clean the residue from the phone edges before re-assembling phone with new screen.
終わりに
To reassemble your device, connect all cables, apply fresh screen adhesive and follow these instructions in reverse order.
12 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Chandler Casey
メンバー登録日: 09/21/18
792 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team S2-G4, Riccardelli Fall 2018 University of North Texas, Team S2-G4, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S2G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 15
今までの合計 3,979
