メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If you need to remove the midframe to gain access to internal components such as the motherboard, front camera, rear camera, and daughterboard, this guide will do the trick!
パーツ
パーツは指定されていません。
  1. Insert a finger nail or plastic opening tool between the back cover and the device.
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Using a finger, pull the SIM card down out of its slot. Remove the SIM card.
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. 全てのタブを開く
    Mac用RAMアップグレードキット
    キット商品を見る
    どれだけタブを開いても
    十分に足りるRAM容量
    キット商品を見る
  4. Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  5. Insert a plastic opening tool between the screen and the back of the device. Starting at the bottom of the device, gently slide the tool along the edges of the screen. Gently pry the main assembly from the midframe of the device.
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
終わりに
4 の人々がこのガイドを完成させました。
Sean Kramer
メンバー登録日: 2018年02月14日
1,248 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team S5-G4, Eyestone Spring 2018 USF Tampa, Team S5-G4, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S5G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 35
今までの合計 1,375
