メインコンテンツにスキップ
Samsung Galaxy Grand Prime Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Grand Prime Motherboard Replacement, Battery: 手順 1、 3の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Battery: 手順 1、 3の画像 2 Samsung Galaxy Grand Prime Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
    Thanks so much. I was getting seriously annoyed. This worked for me. However, I'll be getting another battery just in case. This helped big
    Ana - 返信
  2. Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: 手順 2、 3の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: 手順 2、 3の画像 2 Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: 手順 2、 3の画像 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: 手順 3、 3の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: 手順 3、 3の画像 2 Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: 手順 3、 3の画像 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Motherboard Replacement: 手順 4、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 4、 2の画像 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Motherboard Replacement: 手順 5、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 5、 2の画像 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Motherboard Replacement, Headphone Jack/Speaker Assembly: 手順 6、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Headphone Jack/Speaker Assembly: 手順 6、 2の画像 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
    Hello: Do i have to buy and or replace the audio jack?? If so is it connected by wires, or do i just unplug the audio jack n rreplace it with a new one????
    If i am to just put a new audio jack in, where can i buy one to put in my phone??
    Stephen Miller - 返信
  7. Samsung Galaxy Grand Prime Motherboard Replacement, Earpiece Speaker: 手順 7、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Earpiece Speaker: 手順 7、 2の画像 2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Motherboard Replacement: 手順 8、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 8、 2の画像 2
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Motherboard Replacement, Motherboard: 手順 9、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Motherboard: 手順 9、 2の画像 2
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Motherboard Replacement: 手順 10、 3の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 10、 3の画像 2 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 10、 3の画像 3
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Motherboard Replacement: 手順 11、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 11、 2の画像 2
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
    Sir delivery hoga or price kitnaa
    Kundan Rana - 返信
    C'est de la merde,pour apprendre on ne t'exige qu'une seule langue mais pour apprendre la merde on te l'apprend dans toutes les langues
    Sisyphe - 返信
終わりに
86 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Kyle Ruff
メンバー登録日: 02/04/16
6,725 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S17G3
3 メンバー
12のガイドは作成済み
12 件のコメント
After fixing all the screen, for some reason the LCD was turning on but it showed black and i dont know if is because im missing a screw or because the LCD doesnt work?
Glo - 返信
lol this is likely because you ruined the lcd. this tutorial forgot to mention that it is essential to apply heat, as the midframe is adhered on to the inner component.
connectedcellrepair -
Just need to get a idea on this phone, the silver backing thats usually stuck to the mid frame, when pulling out the old lcd this also came with it.
My question is whether or not that needs to replaced?
Also it changes screens all on its on.
Lisa Yates - 返信
My grand prime 4g board damage
Rakesh - 返信
My grand prime 4g mother board damage
Rakesh - 返信
My said unit was suddenly turned-off. What may possible cause for this problem? Can it be fix?
Felomina Samontiza - 返信
My said unit was suddenly turned-off and it can't turned back as I turn it on back. Can this be fix? What cause this problem?
Wont work. I follow all the struction but when i force t open it, it wont work. Still black out .
Roselyn - 返信
where can i buy samsung j7 prime motherboard .?pls advise..thanks
Mels Dongon - 返信
I try to change g531h touch, but when phone was turn on it screen was off.
I cheked main board and I found u602 and u601 has not volltage ( 3v and 26v). I replaced them but this phone has not screen. would you please guide me?
m.zarrin67[at]gmail[dot]com
mohsen - 返信
i will flash my phone g532f i have forget my email can i djump it ?
alidjekaoua - 返信
My Samsung Galaxy grand prime plus was not working. Was not turn on and doesn't charges
Egno2 - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 69
今までの合計 53,084
