メインコンテンツにスキップ
Samsung Galaxy Grand Prime Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Grand Prime Motherboard Replacement, Battery: 手順 1、 3の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Battery: 手順 1、 3の画像 2 Samsung Galaxy Grand Prime Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: 手順 2、 3の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: 手順 2、 3の画像 2 Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: 手順 2、 3の画像 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: 手順 3、 3の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: 手順 3、 3の画像 2 Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: 手順 3、 3の画像 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Motherboard Replacement: 手順 4、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 4、 2の画像 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Motherboard Replacement: 手順 5、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 5、 2の画像 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Motherboard Replacement, Headphone Jack/Speaker Assembly: 手順 6、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Headphone Jack/Speaker Assembly: 手順 6、 2の画像 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Samsung Galaxy Grand Prime Motherboard Replacement, Earpiece Speaker: 手順 7、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Earpiece Speaker: 手順 7、 2の画像 2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Motherboard Replacement: 手順 8、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Motherboard Replacement, Motherboard: 手順 9、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement, Motherboard: 手順 9、 2の画像 2
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Motherboard Replacement: 手順 10、 3の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 10、 3の画像 2 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 10、 3の画像 3
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Motherboard Replacement: 手順 11、 2の画像 1 Samsung Galaxy Grand Prime Motherboard Replacement: 手順 11、 2の画像 2
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
終わりに
86 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Kyle Ruff
メンバー登録日: 02/04/16
6,749 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S17G3
3 メンバー
12のガイドは作成済み
12 件のコメント
After fixing all the screen, for some reason the LCD was turning on but it showed black and i dont know if is because im missing a screw or because the LCD doesnt work?
Glo - 返信
lol this is likely because you ruined the lcd. this tutorial forgot to mention that it is essential to apply heat, as the midframe is adhered on to the inner component.
connectedcellrepair -
Just need to get a idea on this phone, the silver backing thats usually stuck to the mid frame, when pulling out the old lcd this also came with it.
My question is whether or not that needs to replaced?
Also it changes screens all on its on.
Lisa Yates - 返信
My grand prime 4g board damage
Rakesh - 返信
My grand prime 4g mother board damage
Rakesh - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 22
過去 30 日: 94
今までの合計 53,382
