メインコンテンツにスキップ
Samsung Galaxy Grand Prime Micro USB Port Replacement
必要な工具と部品
  1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: 手順 1、 3の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: 手順 1、 3の画像 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: 手順 1、 3の画像 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: 手順 2、 3の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: 手順 2、 3の画像 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: 手順 2、 3の画像 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: 手順 3、 3の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: 手順 3、 3の画像 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: 手順 3、 3の画像 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Micro USB Port Replacement: 手順 4、 2の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement: 手順 4、 2の画像 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Micro USB Port Replacement: 手順 5、 2の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement: 手順 5、 2の画像 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: 手順 6、 2の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: 手順 6、 2の画像 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: 手順 7、 2の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: 手順 7、 2の画像 2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Micro USB Port Replacement: 手順 8、 2の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: 手順 9、 2の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: 手順 9、 2の画像 2
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Micro USB Port Replacement: 手順 10、 3の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement: 手順 10、 3の画像 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: 手順 10、 3の画像 3
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Micro USB Port Replacement: 手順 11、 2の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement: 手順 11、 2の画像 2
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
  12. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: 手順 12、 3の画像 1 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: 手順 12、 3の画像 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: 手順 12、 3の画像 3
    • Using a soldering iron to solder off the charging port.
    • Be careful soldering iron gets extremely hot.
終わりに
33 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Kyle Ruff
メンバー登録日: 02/04/16
6,749 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S17G3
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 53
今までの合計 34,895
