メインコンテンツにスキップ
Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement
必要な工具と部品
  1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: 手順 1、 3の画像 1 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: 手順 1、 3の画像 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: 手順 1、 3の画像 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
    Thanks so much. I was getting seriously annoyed. This worked for me. However, I'll be getting another battery just in case. This helped big
    Ana - 返信
  2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: 手順 2、 3の画像 1 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: 手順 2、 3の画像 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: 手順 2、 3の画像 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: 手順 3、 3の画像 1 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: 手順 3、 3の画像 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: 手順 3、 3の画像 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 手順 4、 2の画像 1 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 手順 4、 2の画像 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 手順 5、 2の画像 1 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 手順 5、 2の画像 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: 手順 6、 2の画像 1 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: 手順 6、 2の画像 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
    Hello: Do i have to buy and or replace the audio jack?? If so is it connected by wires, or do i just unplug the audio jack n rreplace it with a new one????
    If i am to just put a new audio jack in, where can i buy one to put in my phone??
    Stephen Miller - 返信
終わりに
30 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Kyle Ruff
メンバー登録日: 02/04/16
6,725 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S17G3
3 メンバー
12のガイドは作成済み
3 件のコメント
i seem to find myself with the speaker of microphone connected to the back of the housing.. where as i see your photo in step 5 does't have this. how can I replace this element?
jennpindakaas - 返信
I do this but i think my circuit have problem. When i insert aux, the sound play mono. The phone setting is stereo…..
How can i fix this problem?
Replay me on rabbanihootan71@gmail.com
Hootan Rabbani - 返信
How to me a memory card a default storage on grand prime
Ayandaundetsco - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 14
今までの合計 35,937
