はじめに
This repair is needed to replace the dead battery in your device if it does not turn on, hold a charge, or just flat out wont charge at all.
必要な工具と部品
Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
Go around the edge of the back cover to completely remove it.
Remove the old battery by lifting up on the thumb tab.
Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
51 の人々がこのガイドを完成させました。
コメント 1 件
Should I assume that it is the battery at fault when about 3 location seems a bit warm on the board when leaving the charger on?
