この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide is needed if your midframe on your phone is broken or cracked.
必要な工具と部品
Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
Go around the edge of the back cover to completely remove it.
Remove the old battery by lifting up on the thumb tab.
Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
42 の人々がこのガイドを完成させました。
3 件のコメント
anyone can tell me how to swap vibrator motor?
I need some glue to replace the midframe after having changed it?
not necessary
yasir -
