メインコンテンツにスキップ
Samsung Galaxy Grand Glass and Digitizer Replacement
必要な工具と部品
  1. Samsung Galaxy Grand Glass and Digitizer Replacement, Glass and Digitizer: 手順 1、 1の画像 1
    • Before starting, you need to remove the back case, the battery, SIM card and Micro SD Card.
    • Next remove the screws around the perimeter of the device.
  2. Samsung Galaxy Grand Glass and Digitizer Replacement: 手順 2、 1の画像 1
    • With a prying tool, carefully lift the plastic case covering the logic board and set aside.
    • NOTE: There may adhesive holding the bezel to the midframe. If it is difficult to pry off the bezel, heat it up around edges to soften adhesive. Do not pry on midframe hard at the top edge of the screen it will damage the LCD.
    • You need to place your prying tool in the space between the screen and the case and lift the plastic case towards the back of the phone. Be careful around the buttons.
  3. Samsung Galaxy Grand Glass and Digitizer Replacement: 手順 3、 1の画像 1
    • Here you can see the bottom casing separated from the top, now exposes the motherboard.
  4. Samsung Galaxy Grand Glass and Digitizer Replacement: 手順 4、 3の画像 1 Samsung Galaxy Grand Glass and Digitizer Replacement: 手順 4、 3の画像 2 Samsung Galaxy Grand Glass and Digitizer Replacement: 手順 4、 3の画像 3
    • Remove the cables circled in red by carefully lifting up on them with a prying tool.
    • Remove the flex cable with the green circle by lifting the black clip to the right with a prying tool. See second picture, the clip lifts up and towards the cable (note the line on the logic board. This is how it needs to go back!) Remove the front facing camera and set aside.
    • There is one screw securing the logic board at the bottom next to the Micro SD slot. (Circled in red in third picture)
    • Remove the logic board from the frame (paying careful attention to the flex cables) and set it aside.
    • Now that we have removed the logic board we can safely remove the glass and digitizer.
  5. Samsung Galaxy Grand Glass and Digitizer Replacement: 手順 5、 3の画像 1 Samsung Galaxy Grand Glass and Digitizer Replacement: 手順 5、 3の画像 2 Samsung Galaxy Grand Glass and Digitizer Replacement: 手順 5、 3の画像 3
    • With a heat gun about 3-5 inches above the device, heat a section to enter with our prying tool. Slide the prying tool under the glass (Try to keep your prying tool from going too deep under the bezel of the glass. FAILURE TO DO SO MAY SCRATCH THE LCD.)
    • Go all the way around the screen (be sure to heat if you encounter any resistance. (The adhesive is very easy to get through with a tool when hot) When prying the glass up, be careful around the back button and menu buttons, they can stick to the glass.
    • Once you have pried the glass up, set the home button aside. Release the clip holding the digitizer cable. Now pull the cable through the housing of the phone.
    • Be sure to remove all adhesive and put new adhesive in its place.
    • Route the new digitizer cable through the housing in the phone and insert into slot in logic board. The lines on the cable will match the lines on the motherboard. Replace the home button (be sure to test it for that good ol' click!) and secure the glass.
    • Repeat the steps in reverse order for reassembly.
    • Once you have secured the logic board screw, front facing camera, and pushed all flex cables back in place, insert the battery, turn the device on and test the screen. If device tests successful, reassemble entirely. (I always test my devices before putting them back together and I recommend you do the same, it'll save you time and headaches!)
    • Congratulations, you did it!
終わりに
74 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jeremy Thompson
メンバー登録日: 04/03/14
5,618 ポイント
2のガイドは作成済み
チーム
Hattiesburg Computer Doctor Hattiesburg Computer Doctor人のメンバー
Business
1 メンバー
2のガイドは作成済み
4 件のコメント
I replaced the touchscreen and right now my Samsung i9082 has to be to much sensible to touch. It is a procedure to calibrate the sensibility of a new touchscreen?
Laurentiu TUDOR - 返信
Hello. To the best of my knowledge, modern touch screens do not require calibration due to the way a digitizer is designed to work. It sounds like your replacement is faulty or perhaps a cable is not completely secured. Check your ribbon cables and if those are good contact the vendor you got the screen from.
Jeremy Thompson - 返信
Hi every boss out their…Please does anyone have the idea on how to work samsung i9082 power line from the board?
tinad - 返信
Hello, can someone tell me if there is a difference between the digitizers of GT-19060 and GT-19060C? Thank you.
Decklan Johansen Bedeau - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 91
今までの合計 67,103
