メインコンテンツにスキップ
Samsung Galaxy Gear Band Replacement
必要な工具と部品
  1. Samsung Galaxy Gear Band Replacement, Display Housing: 手順 1、 1の画像 1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Band Replacement: 手順 2、 1の画像 1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Band Replacement: 手順 3、 2の画像 1 Samsung Galaxy Gear Band Replacement: 手順 3、 2の画像 2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
    The screws Phillips are PH000 (triple Zero)
    harnelbe - 返信
  4. Samsung Galaxy Gear Band Replacement, Band: 手順 4、 1の画像 1
    • Loosen the camera ribbon so it will easily pass through the watch body.
  5. Samsung Galaxy Gear Band Replacement: 手順 5、 2の画像 1 Samsung Galaxy Gear Band Replacement: 手順 5、 2の画像 2
    • Grip the body of the watch and pull the band upward.
    • Do the same with the adjacent band, but there will be no camera ribbon to pass through the watch body.
    The adjacent band is not secured with screws. It is just friction fitted. I used a flat head screwdriver to loosen it and then had to use pliers to carefully lift it up out of the housing.
    Lewis Addison - 返信
終わりに
13 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Dalt Lasell
メンバー登録日: 04/12/16
543 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 1-9, Maness Spring 2016 Cal Poly, Team 1-9, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S1G9
4 メンバー
7のガイドは作成済み
8 件のコメント
I have the non camera band (the one with holes )to be changed only. .... but I don't know where to buy it from and how to make sure that it will be the right one for this model SM- v700
Naji
Naji Ajaleel Ibrahim - 返信
Is there a shop in London where I can have this Band changed and repaired by themselves ?
Naji
Absolutely brilliant instructions. Many thanks.
On mine two of the screws were T5 Torx and the other two were T6 Torx, so something to look for.
Roger Palmer - 返信
Please advise are you able to ship to Pakistan
Mehboob Mehmood - 返信
These are very helpful but could do with one more step and pic at the end - for how to swap out the embedded camera.
Dan Bloch - 返信
when will the bands be in stock?
Nick Animations - 返信
I have replace the band, but the speaker is not working, whats wrong?
Ng Anshem - 返信
where can i get these bands?
Pandeni Shuuya - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 40
今までの合計 18,515
