メインコンテンツにスキップ
Samsung Galaxy Fame S6812i Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove Battery Cover: 手順 1、 2の画像 1 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove Battery Cover: 手順 1、 2の画像 2
    • Locate the small indent in the top of the device and use your nails or a spudger to separate the cover from the mid-frame.
  2. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Battery: 手順 2、 2の画像 1 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Battery: 手順 2、 2の画像 2
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: 手順 3、 3の画像 1 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: 手順 3、 3の画像 2 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: 手順 3、 3の画像 3
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  4. Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: 手順 4、 3の画像 1 Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: 手順 4、 3の画像 2 Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: 手順 4、 3の画像 3
    • Locate the two ribbon cable connections on the motherboard. GENTLY use the pointed end of the spudger to disconnect the cables. Lift the motherboard out of the phone.
  5. Samsung Galaxy Fame S6812i Motherboard Replacement: 手順 5、 1の画像 1
    • Using your fingers or a plastic opening tool, carefully lift the motherboard assembly from the phone.
  6. Samsung Galaxy Fame S6812i Motherboard Replacement, Chassis Removal: 手順 6、 2の画像 1 Samsung Galaxy Fame S6812i Motherboard Replacement, Chassis Removal: 手順 6、 2の画像 2
    • On the front face of the motherboard, locate the two #00 Phillips head screws. These hold the SIM card chassis in place.
    • Keep these screws separate from the back plate screws.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Taylor
メンバー登録日: 01/30/15
1,189 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 16-6, Watkins Winter 2015 USF Tampa, Team 16-6, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S16G6
2 メンバー
5のガイドは作成済み
コメント 1 件
How to jumper network problem
Kshitiz khadka - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 1,219
