メインコンテンツにスキップ
Samsung Galaxy Express 3 Rear Camera Lens Replacement
必要な工具と部品
  1. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: 手順 1、 2の画像 1 Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: 手順 1、 2の画像 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Rear Camera Lens Replacement: 手順 2、 3の画像 1 Samsung Galaxy Express 3 Rear Camera Lens Replacement: 手順 2、 3の画像 2 Samsung Galaxy Express 3 Rear Camera Lens Replacement: 手順 2、 3の画像 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Rear Camera Lens: 手順 3、 1の画像 1
    • Carefully push a small pointed tool such as a plastic opening tool (or metal spudger if needed) underneath the camera lens in a corner.
    • Pry up each corner of the lens.
    • Be careful, especially if using the metal spudger, as if you push to hard it can cause damage to the device or yourself.
  4. Samsung Galaxy Express 3 Rear Camera Lens Replacement: 手順 4、 2の画像 1 Samsung Galaxy Express 3 Rear Camera Lens Replacement: 手順 4、 2の画像 2
    • Slide your tool underneath one corner to the other to release the lens.
    • Make sure not to insert your tool too far as it can damage the camera.
    • When putting the new lens in make sure not to put to much force on it as it can break again.
終わりに
作成者
1人の作成者と共同作成されました。
Mack Johnson
メンバー登録日: 04/05/18
996 ポイント
6のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 548
