はじめに
Don't panic if your home button brakes; just follow this guide to replace it. You will have to remove the screen.
必要な工具と部品
Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
Use a plastic tool to remove back and/or recent tabs circuit buttons.
Use a #0 Phillips bit screwdriver to remove the four screws from the black, plastic piece surrounding the home button.
ある他の人がこのガイドを完成しました。
