メインコンテンツにスキップ
Samsung Galaxy Express 3 Battery Replacement
  1. Samsung Galaxy Express 3 Battery Replacement, Battery: 手順 1、 2の画像 1 Samsung Galaxy Express 3 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Battery Replacement: 手順 2、 3の画像 1 Samsung Galaxy Express 3 Battery Replacement: 手順 2、 3の画像 2 Samsung Galaxy Express 3 Battery Replacement: 手順 2、 3の画像 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kellie Speck
メンバー登録日: 04/24/18
136 ポイント
1ガイドが承認済み
チーム
2 件のコメント
Petra:
Hi I’m from Central South America and I recently got this phone for my birthday. I dropped it while at the swimming pool for my party THE SAME DAY I GOT IT and I was really sad. #sad I found your steps a-maz-ing. It helped me not only unclog the water that had corroded the battery inside, but I was able to successfully dry my phone out and replace it without too much hassle. The pictures were especially helpful because English is my fourth language. Thank you Kellie!
Mack Johnson - 返信
I am so thrilled!
-Kels
Stephen Pettinger -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 1,232
