メインコンテンツにスキップ
Samsung Galaxy Express 3 Back and Recent Apps button Replacement
必要な工具と部品
  1. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Battery: 手順 1、 2の画像 1 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Battery: 手順 1、 2の画像 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 手順 2、 3の画像 1 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 手順 2、 3の画像 2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 手順 2、 3の画像 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Screen: 手順 3、 2の画像 1 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Screen: 手順 3、 2の画像 2
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
  4. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 手順 4、 1の画像 1
    • Detach the screen connector.
  5. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 手順 5、 2の画像 1 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 手順 5、 2の画像 2
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
  6. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 手順 6、 3の画像 1 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 手順 6、 3の画像 2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 手順 6、 3の画像 3
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
  7. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Back and Recent Apps Touch Sensor Button(s): 手順 7、 2の画像 1 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Back and Recent Apps Touch Sensor Button(s): 手順 7、 2の画像 2
    • Use a plastic tool to remove back and/or recent tabs circuit buttons.
    • Use a plastic tool as a metal tool can be dangerous to the phone or you.
終わりに
作成者
1人の作成者と共同作成されました。
Mack Johnson
メンバー登録日: 04/05/18
996 ポイント
6のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 574
