はじめに
A problem you may find with your Samsung Galaxy Core Prime is a scratched camera lens. Instead of buying an entirely new phone you can instead replace the camera. For this guide you will need an iOpening tool, a metal spudger, a Phillips #00 screwdriver, or similarly shaped tools.
必要な工具と部品
Use a Phillips #00 screw driver to remove all eight 4mm screws from the midframe.
この手順で使用する道具:iFixit Opening Tool$1.99
Use the iFixit Opening tool to pry off the midframe.
Lift the motherboard from the phone with an iFixit Opening Tool.
この手順で使用する道具:Metal Spudger$2.99
Turn the Motherboard over and disconnect the ribbon connecting the camera to the Motherboard with an iFixit Metal Spudger.
2 の人々がこのガイドを完成させました。
