メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Centura Screen Replacement
必要な工具と部品
  1. Samsung Galaxy Centura Screen Replacement, Battery: 手順 1、 2の画像 1 Samsung Galaxy Centura Screen Replacement, Battery: 手順 1、 2の画像 2
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
    FixBotに聞いてみる
  2. Samsung Galaxy Centura Screen Replacement: 手順 2、 3の画像 1 Samsung Galaxy Centura Screen Replacement: 手順 2、 3の画像 2 Samsung Galaxy Centura Screen Replacement: 手順 2、 3の画像 3
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
    FixBotに聞いてみる
  3. Samsung Galaxy Centura Screen Replacement, Screen: 手順 3、 1の画像 1
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
    FixBotに聞いてみる
  4. Samsung Galaxy Centura Screen Replacement: 手順 4、 2の画像 1 Samsung Galaxy Centura Screen Replacement: 手順 4、 2の画像 2
    • Locate the indentation on the side of the device and gently insert the plastic opening tool into it. With a firm prying motion, the plastic should begin to come apart.
    • Gently pull apart the plastic, and set it aside. The phone should now appear as shown in the second picture.
    FixBotに聞いてみる
  5. Samsung Galaxy Centura Screen Replacement: 手順 5、 3の画像 1 Samsung Galaxy Centura Screen Replacement: 手順 5、 3の画像 2 Samsung Galaxy Centura Screen Replacement: 手順 5、 3の画像 3
    • Pull back the clips located on the right hand side and the upper left side of the phone as shown.
    • After releasing the clips, gently raise the motherboard, exposing the screen from the back.
    FixBotに聞いてみる
  6. Samsung Galaxy Centura Screen Replacement: 手順 6、 3の画像 1 Samsung Galaxy Centura Screen Replacement: 手順 6、 3の画像 2 Samsung Galaxy Centura Screen Replacement: 手順 6、 3の画像 3
    • Gently insert the metal spudger towards the top edge of the back side of the screen.
    • Gently apply pressure to raise the screen from its held position. Continue pulling gently upwards from one side until the screen has been completely removed.
    FixBotに聞いてみる
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Anthony Maldonado
メンバー登録日: 02/28/17
134 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S2-G5, Nance Spring 2017 USF Tampa, Team S2-G5, Nance Spring 2017人のメンバー
USFT-NANCE-S17S2G5
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 52
今までの合計 970
