はじめに
This guide will take you through the steps to replace the motherboard or the zoom lens. Both parts follow the same process until the very last step.
必要な工具と部品
Gather your camera and tools. Also make sure that the battery is removed before proceeding.
Follow battery replacement guide through step three to remove the battery.
Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
Remove stickers off of connectors.
Open latch door on connectors.
Separate lens from motherboard.
Now you may replace either motherboard or lens with new part.
8 の人々がこのガイドを完成させました。
2 件のコメント
Would love a video of this, as well.
