メインコンテンツにスキップ
Samsung Galaxy Camera Lens or Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Camera Lens or Motherboard Replacement, Lens or Motherboard: 手順 1、 1の画像 1
    • Gather your camera and tools. Also make sure that the battery is removed before proceeding.
    • Follow battery replacement guide through step three to remove the battery.
  2. Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 2、 3の画像 1 Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 2、 3の画像 2 Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 2、 3の画像 3
    • Remove all seven 4 millimeter long screws using the PH000 screwdriver bit.
  3. Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 3、 2の画像 1 Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 3、 2の画像 2
    • Use plastic opening tool to remove the cover on the non-lens side of the camera.
  4. Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 4、 3の画像 1 Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 4、 3の画像 2 Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 4、 3の画像 3
    • Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
    • Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
  5. Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 5、 2の画像 1 Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 5、 2の画像 2
    • Use plastic opening tool to pull connector away from motherboard.
    • Remove screen completely and set aside.
  6. Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 6、 2の画像 1 Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 6、 2の画像 2
    • Using the plastic opening tool, disconnect the three connectors from the motherboard.
  7. Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the three 3.5 mm long screws (red circle markers) using the PH000 screwdriver bit.
    • Remove the four 2 mm long screws (orange circle markers) using the PH000 screwdriver bit.
  8. Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 8、 2の画像 1 Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 8、 2の画像 2
    • Remove the three 3 mm long screws connecting the lens unit to the main housing using the PH000 screwdriver bit.
    • Carefully remove the lens and motherboard from main housing.
  9. Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 9、 3の画像 1 Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 9、 3の画像 2 Samsung Galaxy Camera Lens or Motherboard Replacement: 手順 9、 3の画像 3
    • Remove stickers off of connectors.
    • Open latch door on connectors.
    • Separate lens from motherboard.
    • Now you may replace either motherboard or lens with new part.
終わりに
8 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Keith Lipking
メンバー登録日: 09/26/15
359 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 2-3, Wilson Fall 2015 IUPUI, Team 2-3, Wilson Fall 2015人のメンバー
IUPUI-WILSON-F15S2G3
4 メンバー
4のガイドは作成済み
2 件のコメント
Would love a video of this, as well.
David CrossmN - 返信
Hey after you replace the motherboard do you just turn the camera on and it works?
Ive done it and some chinese characters show up in a dialog box...
Sam - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 24
今までの合計 3,375
